Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
automatic primary chain tensioner
Old 10-06-2005, 05:32 PM
billbarket's Avatar
billbarket
billbarket is offline
Default automatic primary chain tensioner
Wondering if it would be wise to go to a automatic primary chain tensioner on a 00 Ultra 1450 SE stage one and if so which self adjuster is recommended?
Hayden M6 self adjuster from J&P
Hydraulic Automatic Chain Tensioner from J&P
The new HD hydraulic self adjuster from Harley
Old 10-06-2005, 06:27 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default RE: automatic primary chain tensioner
I have to go with the HB125 for its hydrallic action over the others https://www.hdforums.com/m_76603/tm.htm
Old 10-06-2005, 09:31 PM
John TN's Avatar
John TN
John TN is offline
Big Kahuna HDF Member
Bill is telling you right, I have the HB 125, good unit, fairly easy install.
Old 10-06-2005, 10:54 PM
cowboy Harry's Avatar
cowboy Harry
cowboy Harry is offline
Been thinking about the auto primary adjuster. Even tho it aint that hard to adjust manualy. What is a HB 125. with out seeing it, Im have a hard time comprehending the hydrolic part of a chain tensioner.????????????
Old 10-07-2005, 12:45 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Take a look here http://www.sohotbikes.com/downloads/instructions.pdf
Old 10-07-2005, 11:05 AM
cowboy Harry
So I take it that thing on the bottem is acually a pump and the tension from the nylon shoe pushes down from the chain thus keep the pump pumped up keeping tension tite.
Have I confused my self yet?
Old 10-07-2005, 01:01 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Not quite, the hydrallic section dampens movement to keep it in the optimum position beter.
Old 10-30-2005, 09:29 PM
traveler's Avatar
traveler
traveler is offline
just ordered the HB 125 through www.foghollow.com for 84 bucks plus shipping!
joe
Old 10-31-2005, 10:45 AM
Taildraggerdave's Avatar
Taildraggerdave
Taildraggerdave is offline
Good advice here.
Old 11-05-2005, 12:32 PM
traveler's Avatar
traveler
traveler is offline
Got the HB125 from Fog Hollow 2 days ago. They sent it right out, got it in just a couple fo days, and I got an e-mail from them thanking me for their business. Seems like a good place to spend your money.
joe
Quick Reply: automatic primary chain tensioner
