Rivera Pro Clutch
Rivera Pro Clutch
I replaced my primary chain and decided to check things out while I had the primary cover off. I removed the 4 bolts from the clutch basket to inspect the plates. When I installed the 4 nuts back on after the inspection, I noticed that the four studs that the nuts go on, are loose. The studs spin with the nuts and will not tighten. Is this normal? If not what do I need to do. The clutch is a RiveraPC-1100-CA.
Thank You Milan
Thank You Milan
IndianHarley
12-12-2020 06:13 PM
jrwca
07-01-2015 07:31 PM
overhead
05-22-2014 05:18 PM
customsoftail200
05-20-2009 08:04 PM
