Inside of Primary Chewed Up
I've been having a banging/clanking that I think has been coming from the primary in an '06 Fatboy. Stock, except stage 1; 10K on bike. Posted in this thread here:
https://www.hdforums.com/forum/engin...nock-help.html
Pulled primary apart and found the inside of the outer primary cover is chewed up. Found a small (1/8") piece if metal in the oil, nothing else seemed at all damaged. Would a 1/8" piece of metal rattling around in there sound like a 1/2" bolt banging around in a coffee can?
Compensator bolt was tight, used a 3/4" drive breaker bar with and cheater and me standing on it to get it loose. Starter ring gear on clutch has a few chipped up teeth on inside edge, starter jack pinion gear teeth are perfect.
Inner bearings are good, sound good with mechanics stethascope, no play, etc... No engine or tranny oil contamination in primary.
I suppose the noise could be coming from elsewhere, like cam bearings; but cant detect anything unusual at idle or revving in neutral.
Ideas?
1/8" piece of metal
Chewed up primary case
Chipped starter ring teeth
Ideas?
1/8" piece of metal
Not the expert for this problem but do have a few questions/observations:
The "chewed up" outer primary cover - the area in question looks dark, not shiny like something new has cut it up, maybe just a manufacturing flaw?
Can you post pics of the compensator parts - wandering how they look, any beat up, scratched up areas there?
That little piece of metal probably came off your ring teeth but I cannot imagine it causing any audible noises.
How well does your bike start up, any kick back or unusal sounds?
Just kinda thinking a bad comp might cause problems during start and be the reason your ring teeth are damaged....
How well does your bike start up, any kick back or unusual sounds?
To me, the comp looks pretty good. I've included a couple of pics. A little worn on the pointed edges, but not too bad IMO.
Bike wasn't tuned very well when I bought it last year, started hard a few times. That could explain the chipped starter teeth. Had the Fuel Pak updated and a new map, fires up easy now. No bang or clunk when starting.
What do you think of the compensator?
Thanks for your input, most appreciated!
To me, like you said, the compensator cam parts look OK. Different model of comp that I had but similar parts - running the Baker now. Can you post a pic of the sprocket retainer?
Those bad starts sound like the culprit for the ring gear but I am still curious what could be causing the loud noises - chain tensioner look OK?
I'll probably replace the compensator.
HDPilot - Chain was right in specs when I pulled the cover, tensionser was good.
Thanks to all of you for your help!
