Shifter Shaft Seal Leak
Recently I replaced the IPB and seal on my 08 Dyna 6 speed and all went well... While in there I also replaced the shift shaft seal. This did not go well, I struggled to get the old one out. I tried various methods I found on forums.
While drilling for a screw hole the bit walked around and nicked the shaft and bore. Yes I got frustrated and careless and was rewarded with a small leak. BTW I was finally able to pull it out using a better shaped pick then used on the first try.
Now I'm thinking about finding a possibly better seal than the current HD then adding an o-ring between the seal and washer and hoping for the best.
Does anyone have any experience with this short of replacing the trans case and shifter shaft?
While drilling for a screw hole the bit walked around and nicked the shaft and bore. Yes I got frustrated and careless and was rewarded with a small leak. BTW I was finally able to pull it out using a better shaped pick then used on the first try. Now I'm thinking about finding a possibly better seal than the current HD then adding an o-ring between the seal and washer and hoping for the best. Does anyone have any experience with this short of replacing the trans case and shifter shaft?
That OEM seal is a real mystery. The early seals were double lip but for some reason in '07 I think, the MoCo decided to return to a single lip seal which makes no sense. The seal in the later models are much more difficult to remove than the early models because the seal "case" is different and fits so close to the shaft that it is hard to drill for sheet metal screws without danger of nicking the shaft; as you have unfortunately discovered. I believe the Cometic PN is C9354 but not sure. When you call Cometic ask if the seal is double lip. If it is, you have a fighting chance; otherwise, the shaft will have to be replaced.
timbo
08-28-2007 09:53 PM
