Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Grinding clutch
Old 04-29-2015, 02:40 PM
EZRider76's Avatar
EZRider76
EZRider76 is offline
Location: Aspen, Colorado-living in a trailer, 4 part time jobs & a 15 yr old HD
Default Grinding clutch
My 2001Heritage clutch grinds when I put it in 1st gear standing still. I have tried adjusting the cable but it doesnt seem to make a difference
Old 04-29-2015, 02:47 PM
Larry Davis's Avatar
Larry Davis
Larry Davis is offline
Try this ..... with engine running and transmission in neutral .....
Do you hear this grinding sound with the clutch lever left out? If so, does it go away when you pull the clutch lever in?
Old 04-29-2015, 03:02 PM
EZRider76's Avatar
EZRider76
If I start the bike in gear it wants to creep forward. If I start in neutral, it grinds before going into 1st
Old 04-29-2015, 07:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,760 Likes on 4,735 Posts
You must adjust the clutch and the cable, not just the cable.
https://www.hdforums.com/forum/prima...-easy-way.html
Toner123
02-28-2016 12:30 AM
marine_hm@hotmail.com
07-18-2012 08:50 PM
502sport
03-13-2012 09:07 AM
spgtti
05-21-2010 06:01 PM
hemel
06-22-2008 08:43 PM
Quick Reply: Grinding clutch
