primary gasket
RE: primary gasket
If all you are doing is changing the oil, you don't need a primary gasket at all. You should only need that gasket for the primary chaininspection cover and the derby cover. It is possible to adjust the primary chain tension without removing the primary cover, it just takes a little practice. I don't think they used o-rings on the drain plug for the 95 models, but I could be wrong. If you do have an o-ring on there, go ahead and replace that as well.
I prefer the silicone beaded style gaskets personally, but either will work fine so long as both mating surfaces are smooth and clean.
cewood
02-26-2008 07:52 AM
