Primary gasket?
Primary gasket?
Having issues removing the previous owners neglect to maintain and keep the bike clean, OK so have a lil OCD.
Planning on a new chrome primary cover, I have a manual, torque wrench (a couple) and handy round the garage. There's a few different kits out there and some with a single gasket and others with oil seals and others included.
The bike, 04FXDI, 10K miles. question is, can I get away with a single gasket or will I need a complete kit?
Thank You in advance.
If you're fitting a new chrome cover you can see the parts you will need in an on-line parts website like this one. It doesn't look as if your gear lever is set in the primary cover, so you won't need any seals, but I reckon you will need the oval central gasket, plus a derby cover O ring, the O ring for the drain plug, plus the main gasket. Hope that helps!
