Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
not much adjustment
Old 02-11-2015 | 06:35 PM
fenwick's Avatar
fenwick
Default not much adjustment
so decided to change my bars last year and before i did i adjusted the clutch and noticed after done the adjuster was almost at the end of adjustment. so when i decided to do the bars i did new clutch cable like most do but after adjusting the clutch after install it is the same almost at the end of adjuster . any insight
Old 02-11-2015 | 06:41 PM
Jackie Paper's Avatar
Jackie Paper
Do not loosen the cable any more but just break the lock nut. Then when you do the back off at the clutch, be sure that once you break the lock nut and screw the allen bolt in to no play, turn it in about 3 or 4 more turns to deburr the thread. Then back it off and back in to no clearance. Now see if you can get some play out of your cable so you have about 1/4" of clearance at the lever but you can still fill some tension if you pull in clutch. Now go back to clutch allen and while levering the clutch with the clutch lever, screw the allen bolt in to eliminate all play. Now back it of 3/4 turn and snug lock nut. (remember the torque on it is pretty small) Now set your cable to 3/32 free play (hopefully will fix the excess cable)
TSheff's Avatar
TSheff
Are you ADJUSTING the CLUTCH or the proper adjustment on the cable???
Old 02-11-2015 | 10:56 PM
qtrracer's Avatar
qtrracer
collapse the cable adjuster, then adjust at clutch basket as per manual.Then adjust cable. Should take care of it.
Old 02-12-2015 | 05:50 PM
fenwick's Avatar
fenwick
thats what idid to install new cable perhaps i should try it again
galtjunk
EVO
14
06-01-2019 04:05 AM
rideflhr
07-03-2013 01:03 PM
coujac
05-13-2012 09:56 AM
hoethree
07-07-2010 08:26 PM
HDHoosier
04-02-2010 08:42 AM
Quick Reply: not much adjustment
