Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
how much play or i guess it might be called travel (not sure on terms) should i have in my shift linkage if any. royu can move the rod back and forth i guess about an inch when at rest. I was thinking it should be tight. should it be tight or loose like that.
