Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
Hand laid flames
Old 08-31-2012 | 09:34 PM
mmitchell's Avatar
mmitchell
Default Hand laid flames
Guys, in 2006 I had hand painted silver flames put on my ultra with no clear coat applied over them, Daytona, drinking involved, anyway they turned out great. I got back from Daytona this year and while at work one of my guys was cleaning a peice of our rental equipment with a pressure washer and some Mean Green, so in my infinite wisdome i actually sprayed Mean Green on my fairing to clean and when I hit it with the pressure washer i screwed up my flames. My color is Brandywine Sunglow. How can I get the flames off without scrwing up my stock paint job. Moral of the story keep strong degreaser off your hand painted sh**!!!
Old 08-31-2012 | 10:59 PM
3408pete's Avatar
3408pete
I would contact one of the stripers/sign painters and ask for their help maybe east woods has some ideas as well .I have used easy off oven cleaner on one shot paints after masking out everything else but it still shows.So about all I can really say is good luck
maybe get them touched up and retain the flames would be as easy
Old 09-01-2012 | 12:17 PM
JRK5892's Avatar
JRK5892
polish... you can use a paint buffing compound and buff them off
Old 09-01-2012 | 12:37 PM
Shortmag's Avatar
Shortmag
Wetsand and buff
Old 09-01-2012 | 01:24 PM
3408pete's Avatar
3408pete
I won't do that--------------due to the extra thickness of the flames and break thru on surrounding paint it will always leave a shadow of the previous design which can be seen from different angles unless you are real careful and block sand the crap out of a catalyzed primer .
Old 09-01-2012 | 01:30 PM
Shortmag's Avatar
Shortmag
After removing with oven cleaner a light blocking with 2000 wetsand will have him looking better than new. It is not something he would probably want to do himself.
Old 09-01-2012 | 01:36 PM
3408pete's Avatar
3408pete
my thoughts to ^^^^^ I would find a local striper that is sober or contact one that travels at the bike shows and ask him his opinion about it --------if it isn't one shot paint I would change up my plan so someone needs to positively id the paint
Old 09-02-2012 | 06:40 AM
mmitchell's Avatar
mmitchell
Thanks guys, its brushed on, seems fairly thick. I think removing them is beyond my skill set. I believe I will get a pro to handle this. Thanks for all of your replies.
Old 09-02-2012 | 06:53 AM
Iceman24's Avatar
Iceman24
Probably a good idea...(pro assist). Have them re-apply flames, or remove & then clear-coat over...maybe even go with entirely new scheme...??
Old 09-02-2012 | 11:45 AM
3408pete's Avatar
3408pete
how about throwing up a picture of the paint and damage---------it might attract someone from the deep lair of a pin striping toolbox
Quick Reply: Hand laid flames
