question to the painters!!!
what pressure should i have my gun set at im running it on 32 right now and it doesnt seem to push the paint threw very well but that could be the gun im using is shity!!!
As soo as i can figure out how to put pitures in my treads ill put some up of my first paint job!! its only vivde black but its smooth no orange peel and no fish eyes and i can read the letters in my tattoos perfect!!!! It was alot of work,,man have new found respect for you painters....
if fish eyes did appear, there is an old trick, & this worked with suction feed guns, crank up air pressure, 80 to 90psi at gun estimated, then spray light dust coat, or a "fog coat" & let "flash" & you can get paint to stick without having to add any additives like "fish eye eliminator" then you clear over like normal.
I used guns like Binks number 7, Sharpe, Develbiss, & had 1 with an agitator cup for larger flakes, for primer I had Japan copies of the Binks 7.
KPS - you're showing some age there..lol...bad part..I remember all of those guns and sprayed with quite a few of them myself. To bad the stuff we got away with then you don't dare do now. Once in awhile you can bury a fisheye but more often times then not you'll just create more work for yourself.
Best bet, take your time make sure you've got a clean surface and good clean air...
my project I am planning to shoot myself, & planning to use my old guns. one of these days I may step up & buy a new fangled gravity fed gun, I have sprayed maybe 10 cars using other peoples gravity fed guns. the only thing I have left is my primer gun, & a Snap-on Sharp model suction gun, & a suction gravity detail gun.
I was heavy into painting in the late 80's through mid to late 90's, & loved the 70's styles. I still do..... planning a heavy metal flake with pearl in a cool shade of orange, & cant decide what kind of graphics.
Later,
Randy
if they are not painted on, several companies make "erasers" specifically for decals. they can be run with a drill & 1 looks like a old gum style eraser, the other is white, & always worked better for me.
for the glue, there is always lighter fluid, & goo gone, or for professional stuff look for a wax & grease remover, something like PPG 330 but test a small area first, they have 1 a little stronger & a weaker one, plus always other chemicals that can be used, but have a strong potential to remove paint. like lacquer thinner, & acetone.
after you remove stripes, since they been on a while, you may have a "GHOST" stripe, in the right light conditions, even through they may not be there, the paint was shielded from UV rays & such & will show a trace difference & will probably be able to tell where they were.
ok went ad got the two part clear coat for 18.96 a can it did two fenders tour pack one saddle bag and a side panel it put two coats on one fender tour pack and saddle bagg not enough to do other fender or side panel but have second can..
Now the point is the best money i have spent on the paint yet well worth it and great info thanks guys!!! It is rock hard will never use any thing else again unless its threw my gun and after useing the two part can with its tip theres not need to use good got a top coat as good as ive seen or as good as i could have done with the gun!!lol
