I will be rattle can painting with HDs Black Denim
Hey everyone. I plan on re painting my tins on my 95 FXDWG next weekend using moco rattle can denim black. I decided to do this for a few reasons. The black paint on my bike now is not perfect anyway and I love the denim look. So I will strip off the old paint use some filler primer then hit it with the denim. Is it really that simple? I can have a under $50 paint job that can look really nice? My buddy told me to take it to a paint shop and have them paint it. Ah no! I know you guys will say hit it with some krylon or other cheaper paint but I think $50 to have a true black denim paint on my Harley is nothing. I will get before and after pics up too but wanted to see if I'm missing something here. I know there are bikes out there with $10 paint jobs that look like they came from the factory too. Also I know Harley has a rattle can flat clear. I was told they don't use a clear on their black denim by both my dealer and you guy but will it hurt anything. I think it would protect it even more.
A lot of folks have had pretty good results with putting the HD black wrinkle on their engines.
As far as putting any rattle can on all your tins.......well yea it can look good at least for awhile. In fact I would guess the texture of the Denim would hold up better than a gloss if you pig spit it often and it's not left in the sun everyday.
The biggest problem with rattle can paint is that it is a one part solution. They can't add a hardener to it so by design it will not be as durable as a two part mix that a pro shop would put on your tins. Of course if you want to spend more money you can buy the 2 part mix yourself at any car body suppy house. You will need a decent spray gun setup.
But again I would guess the denim is the best choice for a rattle can application. But the best primer you can find would help. I have rattle canned areas on my old truck many times. But they only last a year or so before they start to fade badly and latter chaulk off.
Good luck with it though and post some pics when you're done.
(oh and definitely DON'T use clear coat unless you can apply it in a climate controlled setting or it will spider as it ages.)
Light coats indeed. RWB thanks for the great tips!. What is pig spit? Sorry never heard of that! It will be in my garage if not outside at work so that should be ok for the paint. My dad does have a few paint guns for his compresser but I don't really know how to mix paint and hardner and figured heck it's a lot cheaper to get the official denim black from Harley it will be good enough but now you got me thinking otherwise. It will be painted in a clean warm work shop too. Pics will def be going up for this project.
It's up to you but if it where me I would not put clear coat on it. You really don't need it. Just paint it denim and let it cure at least 30 days. Then treat it with any of the above products once a month and it will look great. It's just too risky with clear coat, the humidity, temp etc all have to be right for it to work.
I had some pretty nasty looking water spots on my Bob's blacked wrinkle paint when I bought it used. But I put the HD Engine brightner on it and brushed it around good with a clean toothbrush to loosen up the deposits. Then wiped the engine down good before it dried with a cotton rag. My engine's blacked coating looks new now. It's amazing what this stuff will do to remove deposts of splatter chrome polish etc and then it conditions the paint. Try it sometime.
Got it thanks! That sounds like some good stuff! I hear windex is also good to use. So how many days do you think I can put the bike back together and ride again not 30 days right? . And I will pass on the flat clear then. Funny they did not use it from the factory though. What about gas spills?
I've never spilt any gas on my blacked parts so don't really know but it should hold up as well as any paint. Just try not leave gas on it very long.
