Removing riveted tank badges
My son and I are rebuilding a 2001 Road King Police into a tribute bike for my brother. The fuel tank had badges on the side but they are not attached with adhesive. Rather they seem to be fastened to the tank with rivets. The badges are actually attached by screws to the bracket that is riveted to the tank. There seems to be a rubber gasket between the bracket and the tank.
Any help that you can provide will be greatly appreciated.
I don't think those rivits go through to the tank. I believe they serve more as a spacer for the emblem. The brackets should be held with two-sided tape (thats the gasket you refered to) Getting them off without damaging the paint is possible, just take your time. I use heat and a plastic scraper that I can work under the bracket to lift it slightly so I can cut the tape with a razor blade.
Thanks BeyondThePaint
Thanks again.
frostfamily923
09-29-2008 02:06 PM
frostfamily923
09-28-2008 03:44 PM
