Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
How to remove previous owners paint
Old 08-01-2017 | 08:00 AM
matthew6279's Avatar
matthew6279
Default How to remove previous owners paint
So I bought my 14 Ultra limited used. The previous owner painted a bible verse on the tour back back lip. Doesn't look like its clear coated, maybe just used a paint pen? Any thoughts on remove it? Thanks!
Old 08-06-2017 | 10:17 AM
predatornut's Avatar
predatornut
If it's not cleared you could try some acetone on a rag. If that doesn't work you would have to sand it off.
Old 08-07-2017 | 07:41 AM
Magnut1's Avatar
Magnut1
I would get some 1500 grit paper and lightly wet sand the letters off, that way if you get a little into the factory clear, you can use rubbing compound then polish and wax. I wouldn't use acetone, that might soften your factory paint.
Old 08-07-2017 | 07:58 AM
QC's Avatar
QC
Acetone is a last resort option in this situation. Take it to a paint shop and have a pro do it.
Old 08-07-2017 | 08:06 AM
Uncle Larry's Avatar
Uncle Larry
Greg's right ... be careful with the acetone.
Old 08-07-2017 | 06:22 PM
SiggerTX's Avatar
SiggerTX
If it's King James why remove it?
Old 08-07-2017 | 06:25 PM
Hoginedgewood's Avatar
Hoginedgewood
Wwjd?
matthew6279
I prefer not to have it on there
Old 08-07-2017 | 09:04 PM
missionwop's Avatar
missionwop
Try a clay bar first it may work. If not use 2000 grit paper try wrapping it in some kind if block rubber if possible then sand carefully. once off polish and wax
Old 08-10-2017 | 09:22 PM
Aviator5456's Avatar
Aviator5456
Clay bar probably wouldn't work but I would use 2000 grit wet. It won't eat thru your clear coat as bad and that can be easily buffed out. The acetone probably wouldn't harm the factory paint if used sparingly but the wet sand will do the trick. Good luck.
Quick Reply: How to remove previous owners paint
