BDL PCCB Rear Drive Belt
A staple in the Harley-Davidson rear drive belt world, PartsGiant.com has a giant selection of BDL PCCB Drive Belts to fit a wide range of belt-driven HD motorcycles. Built by Gates, a world-renowned drive belt manufacturer – and the same company that supplies OEM Harley-Davidson rear drive belts, you can expect long-lasting durability along with the confidence to ride on far away from home when you’re rolling with a BDL PCCB drive belt.
Each belt is manufactured using a high-quality polyurethane base that’s reinforced with a tough carbon cord chassis. This so-called X3N material from Gates has proven to be superior when compared to Kevlar (aramid) cords used in other designs thanks to the greater strength of its carbon cord reinforcements. This allows the belt to easily be made with a ribbed outer surface that helps with flexibility, while on its other side, belt teeth are slick and smooth to go easy on pulleys without slipping or excess wear on either part.
Each belt is made in the USA and available on our website for a range of machines for stock replacement applications. We also have additional belts available for custom configurations, just ask!
Get your belt shipped to your fast calling TJ on 888.575.6570 ext. 817 or email forums@partsgiant.com and be sure to mention you saw this post on HDF and he’ll get you sorted out, fast!
__________________
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
www.partsgiant.com
