Feuling Cam Plate Pressure Relief Test Tool
For the serious engine builder, or the novice tinkerer, a cam plate pressure relief test tool from Feuling allows you to correctly check the pressure relief valve on your twin cam engine's cam plate BEFORE it’s installed.
You’ll be able to know the exact pressure at which the relief valve opens thereby allowing you to precisely set spring tension at the desired level. Additionally, any leakage will be noticeable so you can rest assured your next build is going to be oiled properly.
You can read more about these tools on our website here.
Available for use on Twin Cam engines, call us on 888.575.6570 to order yours today!
Everything you need, the tool and instructions, come in the box
Just add the included gasket on this solid piece of aluminum to start testing.
Easy-to-read liquid-filled pressure gauge.
__________________
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
www.partsgiant.com
Harley1004 (08-20-2022)
fuelmoto
Milwaukee Eight (M8)
17
11-25-2023 03:03 PM
Z
Engine Mechanical Topics
23
09-12-2018 01:52 PM
