Motion Pro Tire Pressure Gauge
Proper tire pressure is critical if you expect to have a safe, let alone proper-handling, ride.
A quick, two minute job is all it takes to make sure you're ready for the road, but you need an accurate tire pressure gauge to do the job properly!
Motion Pro's tire pressure gauges are just the ticket.
Available in two pressure reading ranges, 0-30 PSI and 0-60 PSI, each gauge comes with a liquid-filled 2-1/2" dial with easy-to-read hash marks with PSI readings on the outer side of the scale and a KPa reading on the inner side.
The dial itself is affixed atop an aluminum body that also houses a pressure relief valve. The valve's large release button is easily throttled for quick and precise pressure release. Opposite the dial, a flexible hose with swiveling brass fittings at either end is attached which makes getting into tight spaces easy.
Each unit is backed by a two year manufacturer warranty and ships to you calibrated and ready for use!
You can order these gauges on our website here
Pressure readout is accurate to within 1.5%.
Dual swivel brass fittings.
__________________
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
www.partsgiant.com
steelerdude1
07-12-2019 04:26 PM
rollingthunder
07-19-2014 07:48 PM
