std panhead problem plz help
So I bought my softail chopper with a std panhead motor 6 gear trans. Ran good for a while other then it pukin oil out my crank case breather after ever ride. I was riding home and it sounded a little funny when I started it like it wasnt running on all cylinders. When you rev it up it kinda sputterds. I changed all 4 plugs they were super black I started it sounded perfect reved perfect. I go to ride it and it sputters again and acts like my gass is off. I got to down **** to keep up speed and if I give it full throttle it falls on its face and jerks back and forth like its outta gas. And it doesnt back crackle like normal. Anyone have any idea what it could be. I hope my description is helpful. I have an s&s super e carb. I don't know if its valves or accelerator pump maybe carb tuning ignition or what I'm cluess
Tomorrow I'm goin to see if my valves need adjustments. Im tryin simple easy things shops want 65-85 an hour can't afford it right now. I checked ignition and wires to coil changed battery pretty much all the simple stuff is coming to the end lol
Cory, in the main General Chat section you mentioned it "sat for a couple of years". If so one of the first things I would recommend is to drain the tanks, pull them and flush them. Is your fuel filter an "in-line" or is it part of the shut-off valve. Part of your shut off valve is just cleaning the creen; an "in-line" has an arrow point the cvorrect way to have it installed. At any rate change that paper element out with a new one.
so something sticking is what happened - i am not sure how you came to get the correct compression when you did the test, but with an old stock pan nothing should have hit anything so you might be ok - if you put it up again marvil mystry oil is your friend before and after -- johnjzjz
Josh Engle
Shovelhead
21
04-14-2013 01:15 PM
