Best Carburetor for Panhead
Guys, I have a modified 55 Pan (60's style chopper) and wanting a new carburetor!
Presently have a 38mm Zenith, has flat spot full throttle around mid range RPM, plus it leaks badly if the fuel tap is left open and sometimes while ridding...I'm over it.
What would you suggest?
My engine build...S&S Strocker flys & rods, oversize bores, 63 Pan heads - flowed & Andrews valves, double valve springs and Andrews B-Gring cams. 84ci-86ci.
