'65 FL - Stripped inner primary threads
Hey guys,
I'm new here and have a little problem with my '65 Panhead. The threads are stripped on the inner primary where the starter solenoid bolts on, the top hole. Do you think the best repair is a helicoil kit? Or will just a 1/4" longer bolt work? I just wasn't sure if I could use a little longer of a bolt for now, without jacking something else up. Thanks for your time.
Received 3,343 Likes
Hey TwiZted,
What do you mean? Do you think by using a longer bolt temporarily will jack something up? So, lay it on me, dude, I really don't want to jack my bike up, and I don't want to ghetto fix it either, just a time issue right now. If it's something I need to address pronto, I'll do it.
Thanks much.
Thanks much.
Hey TwiZted,
Thanks much.
Thanks much.
You have a 65 so busting something isn't a cheap option to repair , if you have a better old parts supply or swap meets that aren't a hustlers gang bang like out here on the west coast you may find another , used here starts at $300 and trashed ons pull $100 or more .
Those holes are about 7/8" deep but threaded only 5/8" or a shade over . 2 ways to go , helicoil it and you can do it on the bike but you need a real steady hand and a good eye for straight a kit can be had for around $20 or so . Second option is borrow or buy 2 1/4" taps one plug point the other a bottoming tap and chase the threads to the bottom of the hole and use a stud not a bolt so you bottom it out in the hole , only need 10-12 lbs of torque on it don't be heavy handed a Harbor Freight 1/4 or 3/8" torque wrench could be a good buddy to have they are cheap on sale .You should get at least a 1/4" to a good 3/8" thread that way using a 1-3/4" or 2" stud and bit of locktite till you can pull it and get it fixed proper .
Most the time it takes just as long if not longer to ghetto rig something as it does to do right . Watched guys waste a day and half dicking with something rigging it trying to save $20 that could have been done in 2 hours for $25 just pulling it and doing it right .
If you do the tap trick run the stud down for a test fit if it's good a drop of red locktite and let it sit over night should do you fine and just a little heat to remove the stud later .
Hey TwiZted,
I really appreciate you taking the time and giving me a schoolin' about this little problem. The reason I found that the bolt was stripped was because the solenoid stayed engaged one time when starting. I bought this bike about a month ago and I'm still in the 'getting to know' stage if you know what I mean. So while removing the solenoid it was pretty obvious the bolt was stripped. So maybe that's what caused the solenoid to stay engaged in the first place. My solenoid plunger had some major grooves inside, so I was thinking that was the cause of the over-extended starter engagement thing.
Although I generally use the kick, I want everything on my bike to work right. Another symptom I'm having that may be related is sometimes when I hit the starter switch, I just get that sad click, like not enough juice to turn her over. I checked the battery and removed and cleaned every connection, so unless it's some sort of intermittent switch or battery issue, would a mis-aligned solenoid cause this also?
I just received a solenoid and a plunger kit so I plan on jumping into this right away. I'm also gonna grab a heli-coil kit to do the threads.
Again, thanks much for your time.
Sapper-0503
02-11-2019 09:12 PM
