Help identify cases pls?
Gentlemen, please help me identify these cases.
The left one doesn't have radial fins/enforcements for some reason. There is a DMV number instead of the original one, however, it doesn't show up at all on DMV radar. There is also another number to the right with some eagle logos around it.
The stroke is approx. 4.3", the rods are S&S, and the flywheels have "Sumpter spl." stamped on.
Is that an aftermarket?
Some factory re-manufacture?
Received 3,342 Likes
That is indeed a DMV stamped number. Could have been tied into a frame with a Kali 'blue tag' more commonly known as a 'special construction' vehicle.
Numbers to the right with the logo I think might be 'Cal Products' cases from the mid 70s to the e80s? Definitely aftermarket
Have you checked the lower belly number on the right case? If it is HD there should be something there.
