Wiring a 12 volt coil
10-06-2010, 11:03 PM
Does it matter what side of the typical coil that you put the positive wire to and the other that goes to the dist.?
Russ
10-07-2010, 11:40 PM
I don't think it matters cause they aren't labled "+ or -" but the hot wire usually goes on top.
10-08-2010, 09:11 AM
A reversed polarity coil will still run the engine in most cases but it will not run properly.
10-11-2010, 10:22 PM
If the coil is not marked + or - either connector will do Is it one of those round coils with both connectors on top ?
10-17-2010, 12:13 AM
Quote:
Originally Posted by
peppi
Right, in a car where they are maked, if you hook the points to the + side it causes the polarity to reverse in the secondary windings and the plugs fire backwards
geronimo73
EVO
08-13-2020 02:33 PM
sgr60
EVO
20
03-01-2017 05:33 PM
Schwann
11-14-2014 01:04 AM
joker77535
07-05-2013 11:27 AM
run_ride_hide
12-22-2012 05:06 PM
12 ,
12v ,
a12 ,
coi ,
coil ,
coils ,
davidson ,
harley ,
harleydavidson ,
motorcycle ,
positive ,
side ,
volt ,
wire ,
wireing ,
wiring
