OEM Tank Emblems
Received 3,339 Likes
RE: OEM Tank Emblems
I had a few dents in the original 65 emblems, Using a pair of tape wrapped pliers worked well on the outer edges and different sized wood dowels was used to punch it from behind. I rounded or sharpened the ends depending on the angle or depth. Worked ok and you can not tell it was ever dented. Good luck.
[IMG]local://upfiles/10924/8DDCB13C56384115A53AEC55DB6D515C.jpg[/IMG]
