Resurrecting the 65.
Old 05-26-2024, 09:40 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 6,034 Likes on 4,071 Posts
Doing the tops.. Overall length 5.322" and 5.323". They were about 5.335" to start. The KB piston instructions say the cylinders should be 5.330"
The following 2 users liked this post by Max Headflow:
TwiZted Biker (05-26-2024), wfolarry (05-27-2024)
  #212
Old 05-26-2024, 03:06 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 49,066 Likes on 17,935 Posts
Nice, run across some barrels from the mid 70's years there was a .007" taper on the head gasket surface.
  #213
Old 05-27-2024, 07:31 AM
wfolarry's Avatar
wfolarry
wfolarry is offline
Measure that lip & compare it to the recess in the head. You might have to trim a little off that too.
The following 2 users liked this post by wfolarry:
Max Headflow (05-27-2024), pgreer (05-27-2024)
  #214
Old 05-27-2024, 09:47 AM
Max Headflow
I checked and the head sits flush on the gasket surface without the gasket so there is still clearance. The only other issue I need to check is how close the edge of the pistons comes to the head. The cases have about 0.005" removed from the top and with about 0.014" removed from the cylinders that knocks it down about 21 thou. I plan on using cometic high density fiber base gaskets and probably 0.040 MLS.. The cometic base is 0.030 thick. I suspect that the old paper ones are 0.020? The heads have been cut for cleanup so I don't know how much was removed there..
  #215
Old 05-29-2024, 11:47 AM
Max Headflow
I installed the pistons / cylinders without rings and set the heads on without gaskets then rotated the motor. Nothing touched. When setting the ring gaps the second ring was within a thou of spec (0.014). The top rings were set the same so they had to be cut to 0.024" I suspect that these rings are the same as ones provided for the forged pistons which use the narrower top end ring gap..
Anyway, even after washing the cylinder with solvent and a rag, the MMO trick still showed some gray.. It took 4 passes of coating the cylinder with MMO and wiping with a white paper towel before the most of the gray was gone..
pgreer (05-29-2024)
  #216
Old 05-29-2024, 12:20 PM
Max Headflow
Cylinders on. Base nuts torqued to 34 fp.. Got to use a band type ring compressor that's be sitting in the tool box for 50 years..
The following 3 users liked this post by Max Headflow:
65FLpanman (05-30-2024), Architect (06-03-2024), pgreer (05-29-2024)
  #217
Old 05-29-2024, 02:20 PM
pgreer's Avatar
pgreer
pgreer is offline
Received 1,652 Likes on 1,059 Posts
That ring compressor looks a lot like my old Blue Point set I've had for about 50 years. But I've use mine about 3 years ago. They work well.
Paul
  #218
Old 05-30-2024, 08:30 AM
Max Headflow
Paul
MIne says K-D.. Yours were probably made by K-D Blue point was pretty much the stuff snap-on had made by other companies..
pgreer (05-30-2024)
  #219
Old 05-30-2024, 08:55 AM
pgreer's Avatar
pgreer
pgreer is offline
Yep, purchased mine off the Snap-On truck sometime in the mid 70's.
Paul
  #220
Old 06-04-2024, 07:45 PM
Max Headflow
Got the heads back with new seats.. There are a few issues I'm not too happy about but I plan on using them.. One of them was that he resurfaced the heads without welding the fin on.. He did give me the fin off of a shovel.. I would have prefered he didn't surface the heads unless he put the fin on.
Quick Reply: Resurrecting the 65.
