Resurrecting the 65.
Old 04-11-2024, 09:18 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 6,017 Likes on 4,064 Posts
The cylinders before..
  #172
Old 04-11-2024, 09:32 PM
Max Headflow
After a 150 grit wet hone to see how straight they are.. Not Very.. These cylinder really have some serious twists (overheat?) plus what looks like mis-machining..
pgreer (04-15-2024)
  #173
Old 04-11-2024, 09:49 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 49,010 Likes on 17,911 Posts
Poor boring work at a guess. Heat would gall the walls more.
The following 2 users liked this post by TwiZted Biker:
Max Headflow (09-16-2024), pgreer (04-15-2024)
  #174
Old 04-11-2024, 10:24 PM
Max Headflow
Went to 80 grit dry and honed until about 0.0025 to 0.002 under 3.4675. Looks like they will clean up..
The following 4 users liked this post by Max Headflow:
65FLpanman (04-12-2024), Architect (04-12-2024), NM Pan-shovel (04-15-2024), pgreer (04-15-2024)
  #175
Old 04-12-2024, 10:03 AM
Max Headflow
So is this cylinder marking the sign that these are original cylinders?
  #176
Old 04-12-2024, 11:32 AM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,348 Likes on 1,520 Posts
Yes, stands for Motor Casting Company. There will also be a date code on them: month (letter), day (one or two digit number), year (single digit number)
The following 4 users liked this post by panz4ever:
Architect (04-12-2024), MarkSG (04-15-2024), Max Headflow (04-12-2024), pgreer (04-15-2024)
  #177
Old 04-15-2024, 09:39 AM
Max Headflow
Been looking at the heads and rockers. On the heads the current stem protrusion without new guides and seats is 1.580-1.600. Spec'ed max is 1.550. What seats are you guys using?
Interestingly the valves are marked HD and the intakes are close to 0.377" on the unworn spots. The exhausts are about 0.373" which is what I''d expect. Was it standard for the intake to be that size oor are these oversized valve stem.. Measurement taken in the middle of stem. Ends near valve and keeper groove are worn over 0.002. The exhausts have visible scratches near the valve side on the stem.
  #178
Old 04-15-2024, 09:51 AM
Max Headflow
The rocker assemblies are pretty much shoot. All the crap going through the motor killed them..
The shafts are worn down 0.002-0.005 inches from about 0.873" and all scratched up. Rocker ends need regrinding. I might be able to restore 1 set with a lot of work.. Could cut the tops and reem but most of the rockers are pretty much gone.
Are the V twin ones OK?
  #179
Old 04-15-2024, 10:18 AM
pgreer's Avatar
pgreer
pgreer is offline
Received 1,650 Likes on 1,059 Posts
I couldn't find shovel valves (I know I have some new in the box) to mic, but my recollection is that intakes were closer to .375. The exhaust were smaller for the added stem clearance (about .0017 more than the intake). The HD manual I have does not list stem size, only the fit in the guide. I don't recall OEM oversize stems, but it could be. I primarliy used either Manley or Kibblewhite.
Paul
Max Headflow (04-15-2024)
  #180
Old 04-15-2024, 11:00 AM
panz4ever's Avatar
panz4ever
Have a few sets of rocker arms and blocks in mud stash. Let me check them for you. I'll post some pics later today
The following 2 users liked this post by panz4ever:
Max Headflow (04-15-2024), TwiZted Biker (04-19-2024)
Quick Reply: Resurrecting the 65.
