Resurrecting the 65.
#102
#103
Received 3,348 Likes
Max Headflow (01-25-2024)
#104
Got done rebuilding the instrument panel. One thing I noticed was all the outsides of the bulb sockets were connected to power. The gap between the socket and base is pretty close. The 65 wiring seems to power the outside of the socket and use the center pin for the oil pressure, neutral and generator light. I'm going to rewire it so power goes into the center conductor and the others connections are on the socket. That way I only need 1 wire for neutral as I can ground the other side of the switch. The oil pressure switch doesn't change and armature is connected to the outside. That way if any of the bulb sockets get shorted to ground the light simply turns on.. The other way, the wire grounds out the the power wire.
Some of the socket bodies were loose. I dumped a bunch of green Loctite on the fiber insulators and let it work in then let it set up. They are all tight now.
#106
#108
#109
Yeah, It'll probably need to go 30 over to clean up.. One thing is that there seems to be a bunch inexpensive of NOS piston sets on ebay..
pgreer (02-01-2024)
#110
I measured the bore without pulling the cylinder. It miks out at 3.464. If may calcs are correct a 20 over cylinder should be 3.4575 so it looks like I've only got about 0.0035 to do a fresh 0.030 bore at 3.4675.. Hopefully the bore is straight and perpendicular to the cylinder base.
