62 panhead VIN question
Old 07-29-2019, 05:44 PM
heritage_softail93's Avatar
heritage_softail93
heritage_softail93 is offline
1st Gear
Default 62 panhead VIN question
I have been looking for a panhead and have found one that appears to be a good start. The belly numbers match as well as the cylinder heads. The VIN number is something that I am concerned about. It isn't in the expected format. The seller tells me the cases are original. The bike was from California and he thought perhaps it was something the state did for police bikes but I am not sure. I have never come across this before
The VIN is DRF101339
Any thoughts on this would be appreciated
Old 07-29-2019, 07:47 PM
470004's Avatar
470004
470004 is offline
Received 16,311 Likes on 6,750 Posts
Welcome to the forum.
Old 07-29-2019, 07:56 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,861 Likes on 3,024 Posts
you did not say if the vin your reading is actually on the engine cases
in loonie ville west coast they assign numbers to bikes for all sorts of reasons leaving a collectable with out its pedigree - its what you get if you live in the left coast
if you live in calif its fine anyplace else its value is depleted as much as 50 percent
Old 07-30-2019, 07:38 AM
heritage_softail93
1st Gear
Hello,
My apologies for not stating that the VIN is stamped on the case. My research found some old posts in other forums indicating California did this for police bikes but did not specify if the VIN was stamped on the frame or the engine. I thought the cases are aftermarket but the seller indicates that the cases are HD.
Old 07-30-2019, 07:43 AM
Architect's Avatar
Architect
Architect is online now
Received 5,451 Likes on 2,779 Posts
Re-stamp of some kind, either by CHP or some of the bad people. The MoCo would not have used that #, for Police bike or otherwise. Walk away. Post a pic if you want more bad news.
Old 07-30-2019, 08:32 AM
heritage_softail93
1st Gear
Thanks, Here is a pic of the VIN. Tell me all the bad news. I know this bike will never qualify for a restoration project (In my opinion) but I thought it would be a good around the town bike.
Old 07-30-2019, 10:39 AM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,348 Likes on 1,520 Posts
Pic didn’t post. And that number, as mentioned, is not a HD Vin#, not now, not ever, If it was assigned a Special Construction tar (referred to as a Blue Tag, it would have that tag on b oth the frame and the engine.
So while the case may be original, they are not original HD with that number.
Old 07-30-2019, 03:36 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
your research found stupid people that should only answer questions about going on a trip to outer space
you have been advised not to buy this -- as it will not be if it will be taken from you by the law but how long you own it - at some of the events you may go to
then you will have to prove you are not the one who did this to it - and they are not going to believe anything you say with out proof
Old 07-31-2019, 08:12 AM
heritage_softail93
1st Gear
Thank you all.
I decided to pass on the purchase based on input received.
Old 08-01-2019, 02:06 AM
Speeding Big Twin's Avatar
Speeding Big Twin
Speeding Big Twin is offline
Welcome to the forum. I can’t see the photo you posted but I agree it’s a good idea to pass because a bike with a DRF number may be more trouble than it’s worth even though it may be legal. Apparently DRF numbers were state-assigned in California and some say DRF stands for Department Registry File. I’ve seen them on several types of engines including the Sportster shown below.
Sometimes you’ll find a DRF number on the frame of an ex-police bike. In the 50s and 60s when a police bike came in for engine work a replacement engine would be installed on that day. But obviously the bike could no longer be identified by its original engine serial number so a DRF number was stamped on the frame and the DRF number was then used to identify the bike.
Eric
The following 2 users liked this post by Speeding Big Twin:
Architect (08-01-2019), Redrodyankneck (08-06-2019)
doc308
Shovelhead
05-12-2017 07:32 AM
wauschi
05-26-2015 08:04 AM
gpetersen
Panhead
04-20-2015 05:48 AM
kaptekarev
Panhead
09-28-2010 06:06 AM
bayoubilly
Panhead
12-10-2009 12:35 PM
Quick Reply: 62 panhead VIN question
