Panhead oil?
20-50 will work just fine.
As for brand you pick it.
If you are fussy do a 20 min search on the net, you will readily find out who makes the best oil.
Someone will point you to the Fsm and it will say 50 or 60 weight, -but that is all they had back then.
The oil tank is full when hot and 3/4 to the top, I thought they had a dip stick?
Captain Itch (08-14-2018)
Received 3,349 Likes
VR1 is a brand of 50 or 60 wt
Post another pic of that oil tank from the other side...I bet it is a softail tank...which means you could put a softail dip stick in it to monitor the level
.Oil is a religion. No reason or logic required for most people
IDC what you( use .(as i already explained)
I was using 20-50 oil B4 HD ever said it was OK and that was back in the 1970s when Penz oil first came out with it,
Nothing has blown up yet.
It just a better oil..(not necessarily Penx oil)
If you want to discuss it, I think there is a page on this forum just for oil and oil wars.
You ck the oil hot .
Engine off so you don't get tattooed.
