Fuel pump noise
#31
Alright, I've had enough of this nonsense. If theres a filter screen of some sort in there thats really doing some work I don't see why I can't clean/replace the thing before it trashes the fuel pump. I'm going to work on taking mine out and I'll show some pictures of what I find. I literally don't mind adding cleaning this thing to the maintenance schedule if it's reachable when I change my oil and cleab my air filter since everything is already off
#33
I don't know this would be a end-all be all but this looks pretty clogged to me. I've only given it premium fuel from places like Shell and Valero and they've even got the "top tier" stickers 😮
Edit:
the damage is already done and the fuel pump is toasted. Primes like a squealing pig even without the filter. I'll keep an eye on this thing for my 3rd fuel pump.
Final Edit:
There are replacement filters sold on Harleys main website under the OEM parts for $28 a pop. For those that don't want their bike in the shop or needlessly going through multiple fuel pumps-- then while you're cleaning your air filter you might as well flip your tank over, unscrew the fuel pump, pull it out, yank the filter off and pop a new one in if its getting pretty dirty. I feel like its pretty small for the application. Maybe Texas gas is just disgusting, been to a handful of states and who knows what to blame
Edit:
Final Edit:
The following 3 users liked this post by RevenantDescent:
#34
#35
Thats a very interesting point. I could easily pop the filter into place and it would be perfectly secure without tucking it into its little housing spot. Infact, I will do that with my new pump assuming I don't just install a much larger aftermarket filter instead.
#36
Did you try cleaning the strainer? Curious if the black material would come off if sprayed with carb cleaner.
#37
Interesting… there is nothing about the fuel filter in the service manual. Only removal and installation of the pump. Fuel pump screws are supposed to be one time use, manual says to discard them and use new and torque them to 4.5-5.5Nm.
What on earth could be getting into your filter? I’ve had a lot of bikes and none have ever had that much “stuff” in the tank even after decades.
#38
Edit:
Final Edit:
Edit:
Final Edit:
Is it part # 61200083? #6 on this page?
https://www.harley-davidson.com/us/e...a8bb14f77c8a/y
