Connecting Devices to Heated Gear Connectors
The plastic cover on the tank comes off with a couple of screws (it really is just a cover) and then you can run wires from the connectors on the tank - just tape them to it in the middle and around the gas filler hole. I'm running a wire up to power a TomTom fixed on the bars taken from one of the coaxes. I use the other for a heated jacket (Gerbing - very good - it does jacket and then on to gloves).
It's a whole lot easier than in days gone by when you had to take the tank off !
FLSTFI Dave (01-07-2022)
Order66 (06-06-2022)
For those of you that have connected devices (i.e. GPS, etc.) to the heated gear connectors under the seat.
What was the best way that you found to route the wiring from under the seat to the front of the bike? (i.e. GPS mounted on handlebars, etc.)
- Did you run the wires on the left side or the right side of the bike?
- Did you have to remove the tank?
I have the coax to SAE adapters, I'm just looking for ideas on the best way to route the wiring from under the seat to the front of the bike.
Thanks!
Thanks!
![](https://cimg7.ibsrv.net/gimg/www.hdforums.com-vbulletin/2000x1504/1fb971b0_64da_4569_945a_5ec297ec1465_ef3367a0b2656afa8cb085aca50ade7511cad0eb.jpeg)
![](https://cimg8.ibsrv.net/gimg/www.hdforums.com-vbulletin/2000x1504/c009c71d_409a_4246_87e3_35935583cabe_c874e1968b9960f9f1bdf9293f53f38e3f5d213d.jpeg)
