Pan America Pan America Forum Only
PA rear brake
Old 05-14-2021 | 08:43 AM
3dognate's Avatar
3dognate
Default PA rear brake
Those of you that have a Pan America, are you surprised at how much force you have to apply to the rear brake pedal? My brake seems to work fine but I have to mash it pretty hard. I might just need to adjust it's height a little higher and it feel better. The front brake is fantastic...
Curious as to what other bikes are like.
Panam1 (10-17-2024)
Old 05-14-2021 | 02:47 PM
Jed Clampett's Avatar
Jed Clampett
Ha! I literally thought my back brake was out when I left the dealer. I've gotten used to it now!
3dognate (05-14-2021)
Old 05-24-2021 | 12:41 PM
wildandfree's Avatar
wildandfree
Mine was that way until the pads got good and seated. Now it seems fine. Also, don't forget, the front brake lever links both front and rear in most riding modes so that's why it feels so powerful.
3dognate (05-30-2021)
Old 05-30-2021 | 07:13 PM
3dognate's Avatar
3dognate
Quick update... my rear brake feels great now after a few hundred miles. No worries.
The following 2 users liked this post by 3dognate:
BCC1 (05-30-2021), hdxbones (05-31-2021)
Old 05-30-2021 | 07:59 PM
Jed Clampett
Same here.
Old 10-17-2024 | 01:06 PM
Panam1's Avatar
Panam1
Stage II
Mine actually got worse. A blue line down the center of the rotor. Dealer claims ive been riding the rear brake. Not a chance. It is just sub par. Abs used to kick in on a semi aggressive stop. No longer does unless I really mash that pedal. I will be upgrading to busted knuckles 11.8 inch rotor and duel piston caliper.
Old 10-17-2024 | 03:23 PM
tvon's Avatar
tvon
i saw this video about adjusting the height of the PA rear brake pedal.. Never saw this demo'd before.. could help?
Old 10-17-2024 | 05:16 PM
Panam1's Avatar
Panam1
Stage II
https://www.youtube.com/watch?v=VY_H1r52KQo
Mine is the cvo, you simply pull on the tip, 90°parallel to shaft, pull out and rotate 180°
Yours may or may not have that iption depending on the year.
Good luck
donruff
Milwaukee Eight (M8)
06-03-2017 11:04 AM
Bushy
Screamin Eagle CVO Models
09-09-2016 10:18 AM
SGMongoose
2014-2023 Touring Models
15
11-27-2015 06:55 AM
ncbeast
05-30-2011 09:16 PM
Timex
01-22-2009 07:32 PM
Quick Reply: PA rear brake
