Oil Coolers
Oil Coolers
Does anyone have any thoughts about oil coolers. I have been thinking about adding one to my 2005 Fatboy it seems to get hot especially in heavy traffic. I have read good things about the Jaggs but I can not decide on a low mount or one that mounts on the down tube. I thought about an Oil Bud but it is a lot more money. The H-D one that mounts between the down tubes looks like a good idea but I wondering it if is just block the air flow around the heads. I wondering if I should go all the way and add a high volume oil pump. Just looking for ideas.
Oil coolers seems to be a debatable subject among riders. But I'm a believer in them for air cooled engines. Each time I get a new ride, I install a oil cooler on the first service. I've always purchased the ones from HD that I hear are made by Jagg.
All my coolers were installed down low behind tire/fender and work well. One on the down tube would cool a bit better just because of better airflow. Either one you choose should work fine.
What I have found over the years is that a oil cooler works good by itself, but in combination with a good engine tune, synthetic oils, low oil thermostat, oil filter cooler - you will see the best results.
Oil Coolers
I have a HD cooler that is thermostatically controled. I don't know how much more capacity it makes to an oil change. Could not find it in directions. I guess I can just keep adding oil til dip stick says full, But I don't want to add too much and have to drain off the exact amount. Maybe I'm just lazy, but I was hoping to find out a figure in ounces??
How hot does your bike run? The softails, at least in theory, should run a few degrees cooler since they have the external oil tank. My 103ci softail with stock engine runs about 230 on a hot day which to me is nothing to worry about.
HD coolers are no longer made by Jagg. I too have always run a cooler on every bike i've owned. Coolers are like insurance, ya don't need it till ya need it.
