dino to synthetic
dino to synthetic
Going to change to mobil 1 from dino oil. My question is : Are there any issues with the leftover amount of dino that stays mixing with the synthetic that is put in?
You'll notice a sudden "lightness" in your rear pocket. Not to mention your motor will make more noise then it did before. You'll try to convince yourself "it's better oil" so why not?, then when it comes time to change it again, you want to cry as you watch your hard earned money and "better oil" get mixed with all the other oil in the drain pan.,,
oil
I Have to admit, I am using valvoline 4 stroke v twin dino right now and it was noticeably quieter than the HD oil that was in it before. Does the synthetic really run cooler than dino? BIG CAHUNA, I take it you are not a fan of the synthetics, other than noise and cost any other reasons ? Thanks all for your input..
Just me, but running synthetics in harley engines sounds like a harley being run on 7-11 branded 5w30, and yes I heard one run on such oil.
No clue how this equals better protection. I have seen harleys run the same exact engine temp no matter the oil. Engine temp, not oil temp. Psi runs lower, noise is higher, oil passes through the engine so fast it dont have time to grab the heat and take it away from the engine......BAM! Lower oil temps. Oh snap, I gotta run it now, lmao.
On a side note, there is no evidence of one oil or the other hurting, protecting better in rubber to the road reality use. Im sure they do better in a lab under controled conditions where results are easily manufactured. Ive yet to see it on the road.....
Ride more, worry less about oil. The guys I ride with that have the most miles on their bikes use Castrol gtx car oil.
Are there any issues? Emphatically no! They are all oils, designed and blended to meet similar or the same industry specifications. I use synth in one of my bikes, because S&S recommend it in their engine, but my other US V-twins all successfully use good ole dyno.
Not a problem, but if you want to get that residual dirty oil (20+ ounces) out of your system consider a "scavenger" oil change. I use this system http://shop.roguechopper.com/ . There are some homespun ways you can do the same thing. From reading previous posts, I think a lot of people consider this a waste of time. But since I normally am changing oil once a year, and use top shelf fluids, I really like to purge the engine of dirty oil prior to adding new oil.
