Oil Archive (no new posts) An archive of oil related questions and comments.
Oil dripping from breather
Old 03-31-2013 | 02:16 PM
Tdp1313's Avatar
Tdp1313
2nd Gear
Default Oil dripping from breather
I found oil inside breather cover and dripping onto motor,not a lot was able to wipe up, maybe 2 oil caps full. This was after 1200mile trip to Daytona and return. 2011 rgu w13k miles 103 cu. is this normal? I've only put 1500 miles on bike
Old 03-31-2013 | 05:41 PM
HDmikie's Avatar
HDmikie
Try removing half a quart of oil. It worked for me. Even with half a quart less, the oil level was still between the lines on the dipstick.
Old 04-01-2013 | 09:37 PM
despurlock's Avatar
despurlock
I've seen the same thing on my 96 ci and would agree with HDmikie, take out a little oil. Mine seems worse at highway cruising speeds.
Old 04-01-2013 | 09:38 PM
Iceman24's Avatar
Iceman24
Crankcase is over full...called "blow-by."
Old 04-01-2013 | 09:40 PM
jeff.georgalas's Avatar
jeff.georgalas
Use a turkey baster to remove the excess oil, works well.
Old 04-05-2013 | 08:44 PM
Tdp1313's Avatar
Tdp1313
2nd Gear
Thanks for the info. Seems sort of obvious now. I'll defently check oil level.
Bonez76
Screamin Eagle CVO Models
01-20-2019 01:26 PM
blackoktober6
09-30-2016 07:28 PM
barchetta
10-14-2014 07:05 PM
teedubya
07-09-2013 10:19 AM
gnafin
EVO
03-12-2010 04:26 PM
Quick Reply: Oil dripping from breather
