Oil Leak Fixer
Oil Leak Fixer
For years now, I have known of this product but until now dont think I have shared it with anyone on a site. Quick story: I had a leak from the out put shaft on my 95 electra glide. As usual it started as a drop now and then but got worse and worse. I remembered using this product on a bad leak on a huge ferris mower and it worked so I gave it a try. Its called ( SEAL LUBE ) available on the net at seal lube .com . This stuff is guaranteed to stop a leak in anything but brakes. I put 1oz in the trans and over a period of a week or so it stopped completely. It has never leaked another drop. That was 2 full years ago. It costs ( at that time) $20 for 120z but it would have cost probably $75 in parts and all the labor to fix it. It is one of the few products that actually works. It will save you a gang of headaches. I found out about it in a farm journal where all the farmers that used it in their equipt raved about it. Hope this helps someone out here too.
Swells the seals. Keep it away from the primary. Will clog up the friction material in the discs. These bikes are so simple I prefer to replace seals.
