Oil Archive (no new posts) An archive of oil related questions and comments.
07 Ultra - Primary Oil in Starter
Old 12-09-2012 | 10:37 AM
HarleyLarryM's Avatar
HarleyLarryM
Stage III
Default 07 Ultra - Primary Oil in Starter
I have a primary oil leak that is coming through the starter and collecting on top of the transmission. I cleaned and powdered the trans. and confirmed oil is coming from top. I then started checking oil levels in trans and in primary. Over 2wks primary lost a little under 10oz.
I have replaced the primary seal behind the clutch and no gasket leaks. Oil is collecting on top of tran.
I replaced o-ring on starter to primary.
Starter has oil in it and is not rebuild grease.
Anyone have this issue? Fix?
Old 12-14-2012 | 08:08 AM
dynaratt's Avatar
dynaratt
Not knockin your mechanical skills but how much oil are you putting in the primary?
Old 12-14-2012 | 03:50 PM
HarleyLarryM
Stage III
Filling to cover lip when bike is on kick stand. This is about 42oz
Old 12-17-2012 | 08:07 AM
dynaratt's Avatar
dynaratt
Unless things have changed on newer models thats to much oil. Mind you I haven't an 07, the latest Ive owned is 01, so check your manual to make sure here.
On all big twins Ive serviced/owned the bike needs to be straight up and down, not on the stand (same for trans oil check). The only oil lever checked on the jiffy stand is the engine oil. Once straight up and down its filled to the bottom edge of what looks like a stamped metal ring on the clutch hub. All toll no more than a quart ever went into any of the 5 bikes Ive ever owned.
If this is correct on your 07, then Id pretty confidently say the overfilling is causing to much pressure in the case causing it to look for an escape route and the starter is the way out.
Sure hopes this is the problem cause its an easy fix for you.
To add to this I did some diggin here its is in line with my post. 32oz max, bike needs to be straight up and down for visual check. If its drained good just add a quart and you'll be good to go.
Old 12-17-2012 | 08:12 AM
soft 02's Avatar
soft 02
Time to replace you starter clutch. The sealed bearing/over run clutch is leaking.
Old 12-19-2012 | 09:37 AM
HarleyLarryM
Stage III
Nope on too much oil. According to manual you fill primary to lip with bike sitting on angle (kickstand).
I replaced the starter clutch and all is well. Here is a reply from AllBalls Racing;
Larry:
We discovered this issue quite awhile ago (2011) and changed all of our seals to full contact. So, yes, if you received old stock that wasn't pulled from our Distributors shelf it is possible. If you send me your address I will send you a replacement clutch.
Kevin
Bingee
13
08-08-2021 09:43 AM
thumper05
08-13-2014 03:08 PM
06Sportster1200
11-01-2011 01:20 PM
BB
EVO
10-31-2011 07:00 AM
titusvilleharley
10-11-2008 10:10 AM
Quick Reply: 07 Ultra - Primary Oil in Starter
