Oil Archive (no new posts) An archive of oil related questions and comments.
View Poll Results: Which Oil do you prefer?
HD Syn 3
16.30%
Redline
18.52%
Amsoil
29.63%
Royal Purple
9.63%
Other (Please mention in thread what you use)
25.93%
Voters: 135. You may not vote on this poll
Redline / Amsoil / Royal Purple / Syn 3 / Other
Old 08-17-2012, 04:09 AM
sixty4nhalf's Avatar
sixty4nhalf
sixty4nhalf is offline
Not to hijack the post but this puts things into perspective, I switched over to AMSOIL and I too started noticing a "ticking" noise when it was running cold (not so distinctive after the engine was warmed up) so I think I'll be changing it out at the next oil change interval.
  #32
Old 08-17-2012, 07:05 AM
YeOldeStonecat's Avatar
YeOldeStonecat
YeOldeStonecat is offline
Received 5,185 Likes on 1,804 Posts
Usually Castrol V-Twin....all 3 holes.
  #33
Old 08-17-2012, 07:30 AM
rpbrown's Avatar
rpbrown
rpbrown is offline
I have used all that are listed and a few more. I have moved to Royal Purple as my choice in all holes.
With this bike (04 Ultra) I started with RP at the 1st change and noticed it quietend everything down considerably. Had a buddy talk me into Amsoil and that was the most noise my engine ever made. Also was running 20 degrees hotter than with RP.
Drained it and started trying others but came back to RP. It was the quietest and coolest at least in my bike and in this Texas heat.
I will not wander away from it again.
  #34
Old 08-17-2012, 08:38 AM
LDB415's Avatar
LDB415
LDB415 is offline
Which RP for each of the 3 holes? Thanks.
  #35
Old 08-17-2012, 08:56 AM
rpbrown's Avatar
rpbrown
rpbrown is offline
Max Cycle 20/50
As aside note here is an independent test on several oils
http://www.animegame.com/cars/Oil%20Tests.pdf
  #36
Old 08-17-2012, 09:29 AM
LDB415's Avatar
LDB415
LDB415 is offline
You use the 20/50 for all 3? After reading that report, the RP certainly seems superior to any of the others in that test. I don't think I'd go as far as the $30/qt racing RP but the investment for the regular seems like a fair value. With all the talk of extended service intervals and most autos now saying 5k on dino oil and as high as 10k on synthetics is it possible to safely get a little more than 5k on the bike, maybe 6k intervals using RP?
  #37
Old 08-17-2012, 11:38 AM
jakenok's Avatar
jakenok
jakenok is offline
Castrol V Twin or Rev Tech 25 60
  #38
Old 08-17-2012, 12:01 PM
RoadLord's Avatar
RoadLord
RoadLord is offline
No matter what you use, change it every 3,000 miles!
  #39
Old 08-17-2012, 12:09 PM
LDB415's Avatar
LDB415
LDB415 is offline
Was that being facetious and just didn't show in print or serious? If serious, why? The point of the serious synthetics is to extend the service life. Saying change at 3k is like saying throw away the double roll of tp or pt when half used up because that's the full life of a regular roll.
  #40
Old 08-17-2012, 12:12 PM
128auto's Avatar
128auto
128auto is offline
Amsoil 20w50 for motor and primary, severe gear oil for 6-speed.
I have been using Amsoil in the past 6 years, 3 different Harleys, run smooth and cool, never had problem.
Quick Reply: Redline / Amsoil / Royal Purple / Syn 3 / Other
