Oil Archive (no new posts) An archive of oil related questions and comments.
Where can I get Mobil 1 V-Twin?
Old 01-12-2007 | 11:23 PM
dugan's Avatar
dugan
Default RE: Where can I get Mobil 1 V-Twin?
I found some Mobil 1 75/90 so I'll have themput that in the trans. and the V-Twin in the other two and be done with it.
Old 01-13-2007 | 12:21 AM
UltraKla$$ic's Avatar
UltraKla$$ic
ORIGINAL: dugan
That's what I do. You'll be fine.
Old 01-13-2007 | 02:44 PM
pococj's Avatar
pococj
ORIGINAL: 211Chuck
ORIGINAL: Jovimon
I also use Mobile 1 auto oil but only in the motor, Redline heavy shockproof in the tranny and Syn3 in the chaincase. 20,000 miles and all is well, even tensioner pads look good..so far!
Correct" You (CAN NOT) use Mobile 1 car oil in your
chain case at all or your clutch will slip!
Engine and trany are OK" to use Mobile 1 car oil in......
...........BUT" NEVER,EVER in the chain case!!!!!
Why not? I used it there with zero problems. In fact, when I sent a quart of each, car & V-Twin, off to be analyzed there was so little difference between the two as far as additives, that I'd never pay the extra for the bike version. The additive that is supposedly responsible for the clutch slippage is the friction modifier molybdenum. The 15w-50 car oil had 79 ppm, and the 20w-50 bike oil had 91 ppm. Therefore, the bike oil oughtta cause slippage more easily than the car oil. Bottom line is there is essentially no difference between this particular additive, and the car oil won't cause slutch slippage. They're both too expensive to use in the primary, in my opinion.
And I'm moving this to the Oil Forum.
Old 01-19-2007 | 11:28 PM
Dave_E's Avatar
Dave_E
I get mine from G.I. Joes up here in Washington State. As for how much...READ YOUR OWNERS MANUAL.
Wildon883R
01-17-2018 07:54 PM
cdestuck
05-02-2011 10:45 AM
BackinBlackfxdb
08-04-2010 09:16 PM
lance a.
12-20-2008 05:44 PM
99superglide
03-24-2007 11:17 AM
Quick Reply: Where can I get Mobil 1 V-Twin?
