Oil Archive (no new posts) An archive of oil related questions and comments.
Help, magnetic shavings in tappet screen
Old 11-15-2011 | 09:23 PM
Mugster's Avatar
Mugster
5th Gear
Default Help, magnetic shavings in tappet screen
My 94 Evo started making what sounds like a bad bearing noise, so I decided to pull the screen and have a look. The magnet pulled nothing out of the screen cavity, but when I checked the screen it was dirty as hell. Cleaned it down real well, then ran the magnet through the solution run off and came up with a half dozen or so tiny metallic particles that were barely visible. I check the oil for shavings on every change and have never seen anything on the magnets. I'm planning on pulling the cam this weekend to check the bearing, any other thoughts on what to check? How worried should I be about the small number and size of the bits found?
Old 11-22-2011 | 05:17 PM
big cahuna's Avatar
big cahuna
Check your rear lifter. The rear one on mine went south and messed up the motor big time. The needle bearings are known for coming apart, and the bearings get munched up in the cam gears. Check and replace then all if there loose or you have any amount of miles on it. If you lucky this won't be your problem.,,
wild_one
EVO
12-27-2013 06:18 PM
1/2crazedbikr
EVO
08-31-2013 08:38 PM
Beeracuda
05-28-2010 03:06 PM
gunnert
Exhaust System Topics
10-21-2009 11:06 AM
SnailTraX
12-13-2007 06:19 PM
Quick Reply: Help, magnetic shavings in tappet screen
