Check your Mobil 1 VTwin bottle.....
Nvsteve I'm not familiar with mobil 1 15-50 for $6, only the VTwin 20-50 in full syth....is the mobil 1 your describing a syth or reg dino?
Mobil 1 is a group 3 basestock which is conventional. The only "real" synthetic they make anymore is the EP line. I read about them suing castrol and the whole synthetic labeling and my days of supporting that company are over. They are scamming the general uninformed public. Use what you want guys but I will never buy another mobil product again. Rotella t5 or t6 is a great prOduct. Cheaper too
$22 for a 5qt. jug. Heard they were going to start stocking it again.
Humm so this is an automotive Mobil 1 full syth in that weight that a lot of guys are using in their bikes then.....
I have seen used oil analysis that are outstanding.
Check out the 2nd page.
http://www.mobiloil.com/USA-English/...ollection.aspx
Uh...No...the OP`s bike is not made in Japan, but the JASO MA is the only certification for motor oil specifically made for motorcycles.
But any 20w50 oil will be fine in an HD engine. The only bikes that should be using a JASO MA type oil are bikes with flat tappets (oils without zinc additive cause premature wear on flat tappets), or bikes with wet clutches that share the lube with the engine.
I use the 15w50 in both my engine and primary for the last 15k miles and have not had any problems whatsoever. I buy it on sale and always have enough to do a couple of changes stored up.
this is a good thread, as I have been wondering what oils to use myself and my owners manual confused me even more as it says 15-40 diesel oil is an acceptable oil for the engine. If this is so why are we spending twice as much for a syn "bike" oil when we can get a good syn diesel oil way cheeper?
Steve
Steve
