Oil Archive (no new posts) An archive of oil related questions and comments.
At what point can you still switch oil type
Old 06-18-2011, 10:38 PM
NortheastRider's Avatar
NortheastRider
NortheastRider is offline
3rd Gear
Default At what point can you still switch oil type
Have a 06 Road King and have been using dino oil since day one. Now have about 12k miles.At some point I want to switch over to syn 20w50.
I have heard that when switching from dino to syn, the syn oil can actually remove the sludge that is plugging up any leaks, mostly on high mile bikes.
What should the max mileage (or is there one) be to avoid leaking and any other issues when going to syn?
Old 06-19-2011, 02:55 AM
Sefferdog's Avatar
Sefferdog
Sefferdog is offline
Switch and don't worry about it, you will be fine.
Old 06-19-2011, 07:53 AM
troop's Avatar
troop
troop is offline
A simple aid might be adding 4oz of Seafoam to the engine oil and ride it a couple hundred miles before draining. A more expensive aid might be using an oil scavenger system to get out all the old oil. Or just get it nice/hot and drain...
Old 06-19-2011, 07:54 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,414 Likes on 5,014 Posts
Agree with Sefferdog
Synthetic and conventional oils are fully compatable. You can switch back and forth any time with no problem.
Old 06-19-2011, 09:35 AM
NortheastRider
3rd Gear
Thanks..
Old 06-19-2011, 09:44 AM
Dan89FLSTC's Avatar
Dan89FLSTC
And what would that aid?
Old 06-19-2011, 10:03 AM
Sefferdog's Avatar
Sefferdog
Just taking a stab at his intention here, but I think he is saying the seafoam will help scrub out the remnants of the dino before he switches to syn?
I wouldn't go to all that trouble personally. Just drain what is in there now, then fill with your oil of choice.
Old 06-19-2011, 08:14 PM
troop's Avatar
troop
troop is offline
Yup, That's basically what I meant........
Old 06-20-2011, 10:42 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
The only problems you would encounter would be with engines made pre-1994 or with more than 50,000 miles. Just drain & fill no issues. No need to scavenge. I have seen guys switch auto engines at 100,000 miles by doing a 50-50 dino-synthetic mix change for 2 oil change intervals and then go 100% synthetic with no issues. You could also do 2 oil fills with HD Syn3 which is reallly a hydro cracked mineral base oil and then switch to a synthetic if you are concerned.
Old 06-20-2011, 01:33 PM
Sefferdog's Avatar
Sefferdog
112,000 on my 07 and no problems using either oil.......
Quick Reply: At what point can you still switch oil type
