HELP!!!! I Droped a 1/4" drive in motor OIL SPOUT/TANK
You guys can be kinda pushy at times! I had a thread on this very thing some time back so if you realy want to know, you will have to do a little digging to find out.
Not quite the same
Although not exactly apples to apples, I was adding oil from a qt oil can and used one of those pointed lids that comes with Mobil 1 gear oil to put it into the opening of my 'truck', yes my GMC. Since it was hard to get to, and dirty around it, I kept the little blue cap on the opening until I was sure that I could get it close or near the opening. Well as I was tweaking the angle, turning the bottle this way and that way, I accidently went into the hole, and as I pulled it out, the cap stayed in and dropped down into the differental. I ended up adding the oil and then drained it, and plop, out came the cap. Very relieved.
123easypay
Engine Mechanical Topics
05-08-2011 01:47 AM
