oil filter for twin cam??
Ive had evo's in the past and allways used valvoline 20w50 in engine and primary and a stp filter.
I read you need a oil filter with a special release for twin cams?? Do i need to stock up on filters from the dealer? also anyone useing valvoline 20w 50 in a twin cam?
My best recommendation for a TC is synthetic oil 20w50 and the Harley 5 micron filter. TC engines run hotter than Evo's (especially the EFI models) so a synthetic oil like Syn3, Mobil1Vtwin or Amsoil will give you better protection against heat.
Ok couple more questions do i use 3qts in engine and 1qt in primary and can i use syn in primary?
also u check oil while on kick stand correct?
Thanks in advance..
Thanks in advance..
mikey7453
05-06-2012 01:23 PM
Roadkingfatboy
03-29-2009 05:43 PM
