what to run in the tranny and primary?
dumping my dino oil and will be running amsoil 20w50 in the motor.
the more i read, the more confused i get on what to run in the primary and the tranny.
seems like the consensus on the primary is just to dump the same 20w50 as the motor in there.
anyone run anything different?
and as far as the tranny goes...
should i be running an ATF or amsoil's severe gear?
if it's the latter, what weight...75w90 or 75w110...i think 75w140 is a bit much for ny summers, it doesn't get all that hot here.
thanks guys and, well, at least i posted this in the oil section
Others use ATF in the primary with good results.
...and as far as the tranny goes...
Now I am impressed with that many posts since November...but I forgot you guys have winter up there so that gives you more time to post.
Hope that helps!
helpful.
i know it's beating a dead horse, i posted it in the oil section.
are you that bored that you dropped in on a thread you didn't want to read (the title is VERY clear) just to spew some nonsense?
i got the info i was looking for, if it'll make you happy, sir, i'll get a mod to shut it down now so as to not waste anymore of your precious time.
so since i'm dealing with a cooler climate (albeit muggy) do you think i shud go 75w90 or 75w110?
