Oil Archive (no new posts) An archive of oil related questions and comments.
getting ready to do 1K service
Old 04-25-2010, 01:17 AM
rcpilot_971's Avatar
rcpilot_971
rcpilot_971 is offline
Default getting ready to do 1K service
Im getting ready to do 1K service on a street glide what oil should I use and what trans oil should I use
Thanks Tim
Old 04-25-2010, 01:39 AM
JayStronghawk's Avatar
JayStronghawk
JayStronghawk is offline
Amsoil 20W50 in the Engine .. Amsoil 10W40 in the Primary .. Spectro 6 75W140 in the Tranny..
Old 04-25-2010, 06:23 AM
tbob's Avatar
tbob
tbob is offline
Moble 15w 50 syn in motor, Redline Super shock gear in tranny and ATF in primary
K&n 171c oil filter.
Old 04-25-2010, 07:43 AM
big cahuna's Avatar
big cahuna
big cahuna is offline
If you have a warranty that your concerned with, I wouldn't use gear oil or auto trans fluid as they are not factory recommended lubes.,,
Old 04-25-2010, 08:47 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Primary + or Valvoline 20/50 motorcycle oil will work just fine.
Old 04-25-2010, 05:01 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
1+tbob
Old 04-25-2010, 05:09 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Any of the MC synthetic 20w50 in engine & Primary and 75w90 or 75w140 gear oil in the trans. You can also use a 10w40 in the primary.
The oils I would recommend are:
Mobil1 Vtwin
Amsoil
Spectro
HD Syn3
After 3000 miles Redline.
Old 04-25-2010, 05:11 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
My dealer sells BelRay 85w140 gear saver...no warranty problems. They have been using it for decades.
Old 04-26-2010, 12:05 PM
Bluegrasser's Avatar
Bluegrasser
Bluegrasser is offline
After doing months of research I came up with my own esoteric oil combination. I'm thinking about patenting it, because as far as I know it's so unheard of that I am the only one that uses it. Follow along closely, because it can get pretty confusing. What I do is I put Formula+ in the primary and tranny and HD360 20W50 in the crank. It's an odd thing to do, I know, but so far it's working pretty well.
Old 04-26-2010, 08:47 PM
Lost1's Avatar
Lost1
Lost1 is offline
Mobil1 Vtwin
Amsoil
Spectro
HD Syn3
+1
I would also add:
Primary- Formula+ or Rotella 15W-40 HDEO
Tranny- Redline Shockproof Heavy
Quick Reply: getting ready to do 1K service
