Oil Archive (no new posts) An archive of oil related questions and comments.
Primary Oil or ATF fluid??
Old 03-23-2010 | 02:02 PM
TxMongrel's Avatar
TxMongrel
I've been using Dexron for years with no problems.
Old 03-23-2010 | 02:59 PM
paul s's Avatar
paul s
B&M Trick Shift in mine.
Old 03-23-2010 | 03:47 PM
rbabos's Avatar
rbabos
I think it depends on a few things. I tried it and the clutch action was fantastic, however the SE comp made horrendous sounds on shutdown. Put the ams 20/50 back in and it got quiet again. Sudden appearance of more shavings on the magnet didn't thrill me much either.
Ron
Old 03-23-2010 | 07:32 PM
deucegray's Avatar
deucegray
I've used amsoil supershift for 35,000 miles , no problems at all .
Old 03-25-2010 | 03:59 AM
oct1949's Avatar
oct1949
been reading on using the aft.. but the first 25k I've just used formual+
this spring I'am going to M1-Vt.
Old 03-25-2010 | 09:30 PM
Lost1's Avatar
Lost1
First year I had the bike I tried about a half-dozen different oils in the primary, including the $10-$15/qt boutique stuff, and found nothing that worked better for me than Formula+, so that's all I use now. If I couldn't get F+, I'd go with Rotella HDEO.
Old 04-18-2010 | 05:38 AM
Jehu's Avatar
Jehu
Just a thought about ATF and gear and/or chain wear. 4X4s such as SUVs and pick-up trucks (including heavy pick-ups) use ATF in the transfer case where there are gears, chains and sprockets. In some cases that ATF stays in there for the life of the vehicle, oftentimes more than 100,000 miles.
Old 04-18-2010 | 09:13 AM
Lost1's Avatar
Lost1
I have no doubt that ATF will do the job well in the primary- some very knowledgeable folks on this site (and other sites as well) have been running it for many years without issue...
Old 04-18-2010 | 03:15 PM
drjones's Avatar
drjones
Very interesting thread here folks. And a lot of good replies too. Thanks for all the info. TJ
Old 04-18-2010 | 05:23 PM
shadylane's Avatar
shadylane
I've used ATF in the primary for years. The only down side is the dye they put in it. This is to make leaks easier to find. Yes it works....
I'm not a fan of harleys 20w-50 in all three holes nor their primary/trans oil. It makes my clutch drag on cold mornings and causes a hell of a crash when I put it in first gear.
Quick Reply: Primary Oil or ATF fluid??
