Oil Archive (no new posts) An archive of oil related questions and comments.
HD Oil
Old 10-29-2009 | 10:16 AM
bergluke's Avatar
bergluke
Stage III
Default HD Oil
What's the best oil to use in HD bikes? Is it synthetic?
Old 10-29-2009 | 12:20 PM
Haywire's Avatar
Haywire
Yup. Syn for sure in the motor and trans.
Old 10-29-2009 | 01:29 PM
yump's Avatar
yump
4th Gear
Not trying to be a smartass, but the sticky above has 44 pages of response to the question, "what oil do you use in your bike?" There's a ton of info on that thread and other threads about pros and cons of various oils. Try the search function and you can read all day.
Old 10-29-2009 | 10:30 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Ok, you have 7 posts and he has 2....which means you have 2.5 times as much experience on here. cut the guy some slack.
Old 11-02-2009 | 11:57 AM
flipbel's Avatar
flipbel
+1
Old 11-04-2009 | 03:58 AM
bergluke's Avatar
bergluke
Stage III
I'll use search function next time before asking questions. I'm sorry for being new here.
Old 11-04-2009 | 06:05 AM
BigGdawg's Avatar
BigGdawg
I used H-D dino for many years, the weight specified for the motor and recently put in H-D Synthetic 3, Screaming Eagle. Seems to work OK.
Old 11-04-2009 | 06:52 AM
Notgrownup's Avatar
Notgrownup
Welcome to the site...If you change your oil every 2500 miles don't waste your money on Syn....iF YOU GO 5000-7000 then syn might be better...depends how hard you ride too...I went with syn in the crank and primary and inthe tranny but at 20k miles i changed the tranny to severe gear??? can't say i felt any difference..i will use a 75w140 next time and regular primary fluid. Mobile 1 15w50 car oil at walmart for $22 a 5qt container is a pretty good deal. You will get a lot of opinion...read throught the search response and make your own mind up...it's really not that complicated...Like i told somebody else...look at your owners manual.
user 9370
02-24-2017 05:00 PM
jiminpa
05-15-2012 09:06 AM
temporary1
06-15-2011 03:59 PM
wally09
08-29-2010 06:48 AM
young fellow
01-18-2008 08:21 PM
Quick Reply: HD Oil
