Oil Archive (no new posts) An archive of oil related questions and comments.
oil filter cooler ? gimmick or not ?
Old 06-23-2006 | 07:54 PM
NEONNIGHT34609's Avatar
NEONNIGHT34609
Default oil filter cooler ? gimmick or not ?
i found this and i think it might work to a point but it claims 20 degrees ? has anyone used 1 of these ?
http://cgi.ebay.com/ebaymotors/HARLE...52994725QQrdZ1
Old 06-23-2006 | 08:55 PM
Geoseismic's Avatar
Geoseismic
Default RE: oil filter cooler ? gimmick or not ?
I was thinking about it also, but havn't tried it yet. I would like to here from someone who has installed one and monitored the oil temperature of the bike.
Old 06-25-2006 | 05:25 AM
Unibomber's Avatar
Unibomber
While I dont have one, I remember reading a post that basically called that product BS, I dont think HD even makes that part anymore, and you have to wonder just how it can really cool things down seeing its just covering the oil filter, I would be suspicous.
Old 06-25-2006 | 10:48 AM
fl_799's Avatar
fl_799
I bought a cool collar for my '06 Dyna (for testing purposes) and it does lift **some** heat from the oil filter plus it looks nice. Can you feel a difference? Not really. Is it a replacement for an oil cooler. No way.
I still added the HD premium oil cooler and there is no doubt the engine is running way cooler then before. So I run them both on my bike. Can't hurt right?
For the price, the cool collar's polished billet looks 'trick' and fits tight. Cheaper then the decorative Ness filter covers and you even might get a few degrees out of it.
Old 06-26-2006 | 02:20 PM
bobcowan's Avatar
bobcowan
It's not a cooler, it's a heat sink. In order for a heat sink to work, it has to be in full contact with whatever it's pulling the heat from. The lip on cover only comes in slight contact with the filter case, in only a couple of points. The air gap left between the sink and the case will insulate the filter; that's how your double pane windows work. If you filled the void with heat transfer grease, it would work better.
I've seen some filter cases with cooling fins and a replacable filter element. They would work better.
Old 06-27-2006 | 01:33 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
This is true......for heat transfer there should be complete physical connection with the hot oil for heat to transfer through the metal to the air. Most likely very inefficient. IMO.
ORIGINAL: bobcowan
Old 12-21-2023 | 03:26 AM
Lostintennessee's Avatar
Lostintennessee
6th Gear
Default Oil filter heatsink
Sickspeed has something like this..in multiple colors..found them on ebay..fars I can tell it's 100% contact. Not sure if it's considered snake oil but..Happy Holidays everyone!!
Old 12-21-2023 | 04:30 AM
Andy from Sandy's Avatar
Andy from Sandy
That was 17 years ago now!
My take is HD engines have an optimal running temperature and oil likes to be warm as well to flow. If you over cool the oil neither will not reach those temperatures.
Where I am a cooler would be some vanity devise and is not needed.
Old 12-21-2023 | 06:40 AM
Screamin beagle's Avatar
Screamin beagle
Holy thread resurrection Batman. I was excited to see the 2006 on the original post but usually somewhere between then and today there will be a few post mixed in over the years thereby taking it out of the running for record. While this is pretty darn impressive it is not a record breaker but it is in the top 5 ,slotting in at #4...congratulations Mr thread resurector guy you have accomplished a rare feat here. However there are no participation trophies here at hdforums.com and "we" only award "prizes" for first place but welcome to the greatest HD forum on the internet.
Old 12-21-2023 | 07:16 AM
t150vej's Avatar
t150vej
I'm impressed by anyone with enough common sense and determination to actually use the "search" feature. And, old thread resurrection can be useful at times. Good job Lostintennessee
scootertramp
05-03-2013 09:59 AM
fabrik8r
06-15-2011 09:56 PM
07fatboycustom
03-14-2010 05:14 PM
lmb1485
01-19-2008 01:33 AM
RICBME
09-30-2005 12:04 PM
Quick Reply: oil filter cooler ? gimmick or not ?
