rookie mistake changing oil
okay, 2007 road king, instead of draining the oil. I drained the trans oil. Not knowing that, I added 3 qts to my engine to make it 7. Needless to say I over filled and now have oil coming out my air filter. I drained and refilled with just the four. Still I have oil coming out my air filter. Help?
Received 4,762 Likes
The engine oil requirement is 2.5 qts doing a normal oil change. If the engine has been taken apart for repair then the oil requirement is 3 qts. The oil drain plug is on the jiffy stand side of the oil pan. The newer trans take a different qty than my 05, hope this helps out.
Thanks for putting the mistake out there.
KippTJ- Thanks for having the courage to put your mistake out there... I am a first time HD owner and will be changing the fluids this weekend coming up for the first time and because you posted your error, maybe I will not make the same.
I hope you get your problem solved quickly.
If I hadn't gotten a service manual, i would have made the same problem. I would have never guessed that I would drain my oil where it was on an 05 Deuce.
it shows full, which I don't understand. The bike isn't running right now, I assume I fouled a plug or both. I will drain some. since I put so much oil in, I didn't know if its in a different area and just needs to drain out.
If you contact the dealer you would get questioned about not letting the dealer do the work so here's another way. What ever model you have go that particular forum or under "General Harley Davidson" and ask how much in each hole. Hole 1-the engine w/filter is 2.5 qts after re-filling the engine oil run the bike and check the oil level. Hole 2-the transmission, fluid qty particular to model. Hole 3-primary loosen the derby cover very carefully so that the heads don't strip out, (wouldn't hurt to have some spares on hand if this the first time off) again qty depends on model. Yes, you'll catch some flak from some but some will help you out. Good luck
