Oil Archive (no new posts) An archive of oil related questions and comments.
Dumb Q about changing Oil Filter
Old 06-23-2009 | 09:18 PM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by Arizona
You'll be about a 1/3 of a quart low after a filter change. Add it slowly and check it a few times till you know it's at the right level.
He already put 5 qts. in!
May be he has a Baker oil pan?
Old 06-23-2009 | 09:24 PM
Whackone's Avatar
Whackone
Look in the good book and it says 4 quarts with filter, do not overfill or the god of pucked out oil, through the air cleaner will get you. Change the filter and you will be just right or maybe a little over full.
Old 06-24-2009 | 01:30 AM
nighttraingirl's Avatar
nighttraingirl
Well I learned something today. I sure never knew that you could take off the oil filter without draining the oil. (not that I ever needed to). But you never know I might have a brain fart someday and forget to change the filter. By then I will have probably have forgotten this useful info. LOL
On a side note if you did have to drain the oil, couldn't you just drain it into a clean container and then pour it back in after you changed the filter? That would probably be what I would have done instead of thinking to ask.
Old 06-24-2009 | 06:13 AM
alame's Avatar
alame
yeah you could do that, but after all the good advice given here your problem is solved
Old 06-24-2009 | 08:46 AM
freebyrd's Avatar
freebyrd
one other piece of advice when installing a new filter put a little oil on your finger and rub it on the new gasket
tighten finger tight til snug and then give it about 3/4 of a turn after that
Old 06-24-2009 | 08:50 AM
DeckerDude's Avatar
DeckerDude
Originally Posted by 1FLTRI4ME
5 qts????
That's what I was going to say.
Old 06-24-2009 | 08:51 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Sponsor
Mobil 1. Much better than syn 3 any day of the week. Even the 20w-50 vtwin is a little cheaper at autozone than syn 3 which is not a full synthetic. "nuff said...
__________________
Old 06-25-2009 | 04:34 PM
davidtn's Avatar
davidtn
I'm too lazy to check the other threads and if you don't answer my question I'll understand, but...why do you say Mobil 1 is better than Syn? Can one synthetic oil be THAT much better than another?...price notwithstanding.
Seascape
05-18-2010 06:27 AM
btroy
EVO
19
09-28-2008 10:56 PM
rumblebee
04-25-2007 05:14 PM
John3:16
04-24-2007 02:53 AM
smithr
22
08-22-2006 01:23 PM
Quick Reply: Dumb Q about changing Oil Filter
